Duraspark II Problems
Old Jan 30, 2004 | 01:51 PM
bearfoot_25's Avatar
bearfoot_25
Unhappy Ignition left on > Duraspark II
i have a duraspark ii ignition system. the other night i left my key in the on position while b.s. ing with a friend,for about an hour. now my truck will not start!!!!! i replaced the ignition box on the fenderwell and also replaced the distributor! what else could it be. i have also checked all of the supply wires and everything seems to be fine, but no or very little spark whatsoever!!! and the truck still wont run it just keeps turnig over and nor firing. also checked fuel supply, plenty o fuel!!!! can anyone help me out here????
Upper Case Edited out by FTE
Old Jan 30, 2004 | 07:59 PM
RTM's Avatar
RTM
coil?
Old Jan 30, 2004 | 09:06 PM
ATC_250SX's Avatar
ATC_250SX
What Year, what motor,? and a coil is all you have left so seems like it would be next on the list, unless you didnt put in new pickups under the rotor those ar said to go, i had this problem with my 87 f-150 with the 5.8 but it was the igniton modual, cheap and easy fix,
Old Jan 31, 2004 | 10:43 AM
bearfoot_25
yes the whole distributor is brand new. ok, i put in a new coil last night still no fire to the plug wires!!!!!!!! heres a recap,
replaced whole distributor
replaced the control module
replaced the coil
checked the supply wires for the coil and module
still no fire to the plug wires!!!! the only things left to be replaced are the cap, rotor and plug wires wich were all purchased about 2 weeks ago before i had this problem!
it is a 302, and ignition system out of an 82
Old Jan 31, 2004 | 02:23 PM
RTM's Avatar
RTM
Is the distributor turning when you crank the engine? This is a tuff one.
Old Jan 31, 2004 | 02:48 PM
bearfoot_25
yep distributer is turning, i also replaced the cap and rotor to be sure.it tried to run for a few rotaions but then the fire went away again!
Old Jan 31, 2004 | 04:15 PM
RTM's Avatar
RTM
Do you still have power at the coil with the key in the run position and the start position?
Old Jan 31, 2004 | 04:47 PM
bearfoot_25
yes, it does. well everything is new, i guess im going to try to clean up the connectors in the wiring when i get home
Old Jan 31, 2004 | 08:16 PM
ATC_250SX's Avatar
ATC_250SX
Aolmost sounds like a bad ignition switch, if you look on the internet youll find some wireing diagrams for it, there are two power wires one if i remember has a resistor somewhere, if thats gone it may not have the right voltage to spark. oh and just an after thought, dose it have a condenser mounted to the coil?i know my 87 has one that could be bad therfore causeing not enough voltage to spark.
