Removing Front Rotors
Old Jun 30, 2004 | 03:13 PM
cwb's Avatar
cwb
Oh wait. Can't you just take off the caliper slide bolts(allen head as I recall) and get the rotor off?
Old Jun 30, 2004 | 09:44 PM
omnimax's Avatar
omnimax
An air compressor and pneumatic tools just went on the must have list. Fronts are done and I am going to do the rears in the morning.
cwb-
Have to take off the capliper slide bolts to get to the pads, but the caliper mount bolts also have to come off to get the rotor off.
Old Jun 30, 2004 | 11:38 PM
cwb's Avatar
cwb
Cool!!......
Old Jul 1, 2004 | 12:50 PM
omnimax's Avatar
omnimax
Did the rears in about 3 hours this morning and passed my inspection. These ART rotors and pads take all the sport out of driving. There's no shaking, jerking, or pulling when I hit the brakes. This will take a while to get used to.
Old Jul 1, 2004 | 12:57 PM
cwb's Avatar
cwb
Glad to hear it worked.
Old Jul 7, 2004 | 11:46 AM
omnimax's Avatar
omnimax
What color loctite should be used when putting the brakes back together? I didn't use any when I put them back together last week. I checked the torque after the trip to North Carolina and didn't notice any bolts being loose. Called today about getting all new bolts for the brakes and they're going to be $72.00. I was thinking about getting those in and then using the loctite. I bought a tube of Red Medium when I was getting all the stuff for the brake job, but wasn't sure whether to use it or not. Only a couple of the bolts are rounded a little bit so I might not replace all 16 bolts.
Old Jul 7, 2004 | 12:00 PM
cwb's Avatar
cwb
Blue. Don't use red.
Old May 10, 2012 | 11:11 AM
Homer Simpson's Avatar
Homer Simpson
2WD Front Rotors
How should the front rotors look for a 2000 2WD Excursion:
Photo #1 - With Studs:
OR
Photo #2 - Without Studs:
When I do searches online for parts, I get both kind. On Adv Auto the difference in price is ~$60 for no studs and $102 with studs.
Also, if with studs, do you have to remove the hub and cotter pin to remove the rotor?
Thanks,
Mr. H. J. Simpson
Old May 10, 2012 | 12:54 PM
XbigXredX's Avatar
XbigXredX
Mine is a 4x4 and picture 2 no studs is what my rotors look like. They slip over the 4 wheel drive hub. I would presume picture 1 is for a 2 wheel drive where there is no 4 wheel drive hubs. I am not 100% sure but that would make perfect sense imho.
Old May 10, 2012 | 11:02 PM
chetspencer's Avatar
chetspencer
Originally Posted by Monsta
Just on really tight. Make sure YOU are turning them the right way since you are looking at them in reverse.
A shot of Weasel ***** on the bolts wouldn't hurt either.
* WD-40 or the like...
I was taught as a Marine machinist to use Panther ****.
Old May 11, 2012 | 12:29 AM
wpnaes's Avatar
wpnaes
Don't forget to grease the rotor / hub surface for the 'next guy'!
Old May 11, 2012 | 01:31 AM
Monsta's Avatar
Monsta
Sit. Stay.
2wd rotors are the top picture. (just confirming what XbigXredX said. )
Panther, Weasel, gorilla...they all work!
A mix of Acetone and Tranny fluid is the best BTW.
This is a freakin' old thread!
robjs111
1978 - 1996 Big Bronco
Aug 27, 2011 10:38 PM
OneTon4Fun
Sep 1, 2009 09:06 AM
antoine
Feb 28, 2006 08:45 AM
FDXMAN
Jan 11, 2004 07:48 PM
Rsquared
Jun 21, 2001 09:46 PM
