Oil & Lubrication
iol leaking problem
Old Jan 30, 2004 | 07:37 AM
gearshift101's Avatar
gearshift101
iol leaking problem
Hello!
I found oil spots on ground, at the front part of the engine. When I looked under the truck I found heavey grease build-up sitting on the axle frame dead center. The color of the spots in the snow, is rustic looking and smells like gas.
The oil spots, where not just in one spot, they where maybe a couple if inches apart.
can anyone tell what or where thats coming from. could it be the front engine seals leaking?? (or) ???
Thanks Al
Old Jan 30, 2004 | 09:11 AM
f100guy's Avatar
f100guy
it could be anything but if it is under the front mostly then most likely is your front main. how many miles is on it
Old Jan 30, 2004 | 08:33 PM
therion's Avatar
therion
Re: iol leaking problem
Originally posted by gearshift101
Hello!
Thanks Al
prolly the crank seal.
