79 f-150 4x4-Electrical problem
Old Jan 30, 2004 | 06:29 AM
cob white's Avatar
cob white
The instruments, turn signals, and radio just started to work intermittently. The outside air temp has been around 20 deg F for about a week, and w/getting in & out w/snow on my boots there is a lot of moisture in the cab. When first started up, none of the above work. After the heater runs a while, they start working. Could this be the fuse box, or somewhere else? Thanks.
Old Jan 30, 2004 | 11:02 AM
LxMan1's Avatar
LxMan1
Sounds like a bad chassis ground somewhere.
Old Jan 30, 2004 | 12:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
A bad connection somewhere but the fuse panel is probably a good point to start looking. Look for discolored wires or connections that may be the signs of overheating. Usually a bad connection will heat the wiring at that point.
