Oil & Lubrication
castrol 20w50
Old Jan 29, 2004 | 09:55 PM
f100guy's Avatar
f100guy
castrol 20w50
what is this oil used for and is it good for a 2000 v6 mustang.
Old Jan 29, 2004 | 10:25 PM
TallPaul's Avatar
TallPaul
A 2000 V6 Mustang should do fine on 10w30. I also wonder what 20w50 is used for. Oil burning beaters, hard driven hot rods, and older engines in really hot climates I suppose.
Old Jan 30, 2004 | 01:31 AM
Rand's Avatar
Rand
a 2000 stang.. unless you live in death valley 10w-30 should be fine. 5w-30 in the winter if you are somewhere cold.
If you beat on it daily in 100+ heat maybe a 15w40
Rand
Old Jan 30, 2004 | 01:35 AM
f100guy's Avatar
f100guy
i use 10w30 in all of my non oil burning and leaking cars and trucks. but my friends dad works at napa and says that 20w50 is for high revving engines. so he bought me 5 quarts for taking his el camino to the paint shop for him. should i use it. i live close to houston,texas. and i am going to try to take care of this one better lol
Old Jan 30, 2004 | 10:18 AM
oppy's Avatar
oppy
Not that many years ago, Castrol was telling everyone to use GTX 20W-50 exclusively. Nowadays that's not the case. I think if you wait for that nice warm Houston summer, you won't have any problem using it. After that, I think the other guys are right on - stick with 10W-30.
Old Feb 1, 2004 | 09:18 PM
f100guy's Avatar
f100guy
so i guess i will save this stuff until summer which i am still hesitant to use since i have never done it before. i don't run anything more thatn 10w30 and 10w40 and that is on oil burnes. what will this thick oil do to my motor
Old Feb 1, 2004 | 09:23 PM
BlueRanger94's Avatar
BlueRanger94
A few years back I had a Taurus and used 20W50 in the summer. It did not affect the motor in any bad way.
Old Feb 3, 2004 | 07:51 AM
hceptj's Avatar
hceptj
Summers in Houston are fine for 20W50. Castrol makes great oil and the price was right for you...
I used to run 20W50 in my '68 Camaro (383 c.i.) in the summers in Oklahoma but would switch to 10W40 in the winter.
Like they said...great for older cars w/higher mileage engines...help keep the leaks down...but will be fine for your car in the summer...
Old Feb 3, 2004 | 08:06 AM
TallPaul's Avatar
TallPaul
Since you understandably are not comfortable running straight 20w50, why not run one or two quarts of the stuff mixed with 10w30. I would stay with the same brand for both grades. Four quarts of 10w30 mixed with one 20w50 likely would still give you a 10w30, just a thicker one. Even a ratio of three 10w30s to two 20w50s probably would barely get you to a 10w40, maybe a 15w40. It won't hurt. I ran 2 20w50s mixed with 4 5w30s fine (not normal procedure, just an experiment), just not in sub freezing weather.
Old Feb 4, 2004 | 07:14 AM
TritonV10's Avatar
TritonV10
Paul ,
I have seen many posts like this across the internet but it is simply not possible to better engineer a formulated oil in this manor of mixing . Oil is a science and even more so these days with ever changing additives and the proven synergy of manipulating these additives used together by the chemists that are paid big bucks for their work .
Now it might not hurt to use up that quart of leftover oil on occasion but making it habit is really not the best practice .
If cost is an object I would use Motorcraft 10-40 or one of the several new blends or any available group III synthetic 5-40 in that V6 during Houstons summer where the overnite low is 80F .
Old Feb 4, 2004 | 10:29 AM
TallPaul's Avatar
TallPaul
Originally posted by TritonV10
Paul ,
No, I would not advocate such mixing on a regular basis (and I was not intending to "better engineer" the oil), but to use up the 5 quarts he received, it should not be a problem. I would mix oils if the oil company says it is OK. For example, Valvoline told me I could mix the regular and synthetic Maxlife (when it comes out).
Old Feb 6, 2004 | 01:02 AM
Big Yac's Avatar
Big Yac
I have 6 qts of Valvoline 20W50. Would this be ok to use in my truck, its a 91 F150 w/ 302 with 90,000 miles on it. Ofcourse I wont put it in during the winter, we really dont get alot of terribly hot weather here in Ohio. Are there any advantages to 20W50 in a truck like this? Would it be better if I just stuck with my usual Valvoline 10w30?
Old Feb 6, 2004 | 06:11 AM
peppy's Avatar
peppy
I had 20w50 in my Pontiac in Ohio. Never had any problems in the summer time. But I was hurting that motor as much as I could. I cant think of any reason to use 20w50 in a sound motor in Ohio. If you just want a HD oil, you can use a straight 30w. I have a 91 F150 w/ a 302 over 100,000 miles and I use Mobil Drive Clean 30weight year round. I'm very happy with Mobil oil. Its even eating the varnish off the dip stick, after years of lesser oils.
I cant remember the safe pour points of 30w in the winter, but outside of winter months you can use 30w easily. With the winter temps there, I'd stick with your 10w30. Or maybe even a 10w40 year round if you prefered.
Old Feb 6, 2004 | 02:08 PM
TallPaul's Avatar
TallPaul
Call Valvoline (1800TeamVal). Ask them. If you put 2 20w50 with 3 10w30 you should be fine, IMHO. As I said, I ran 2 20w50 mixed with 4 5w30s in my '95 F150 300 straight six with no problem. Just don't do it in sub freezing weather.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
