Big Balls vs Ball joints
Old Jan 29, 2004 | 05:28 PM
Brad Brown's Avatar
Brad Brown
Big ***** vs Ball joints
Hi all, I have a 74 crew cab with a dana 60 (60F) in the front and a 78 super cab with a dana 60 in the front.
The 75 has big ***** at the wheel instead of ball joints ,I don't know what these are called.
The 78 has ball joints and a u joints like normal.
Which one is better? I had the 78" redone a few years back so I know it is good, but I have never had any experiance with the big ball unit! I am using the 78 as a donnor truck and want the best for the crew cab! Thanks a bunch!
Old Jan 29, 2004 | 07:37 PM
oldhalftons's Avatar
oldhalftons
the "big *****" dana-60 is called a closed knuckle , the ball joint dana-60 is called an open knucke.
I believe the open knuckle design is considered stronger.
Old Jan 29, 2004 | 08:38 PM
Brad Brown's Avatar
Brad Brown
Thanks for the info! The other question I had was the springs, the 78 has the 2 leaf bent over the drive shaft design and the 74 has the multileaf design, the bent over two leaf ones are new last year, however I don't know if they are going to work with the 35 X12.5 by 16.5 inch tires. any ideas?
Old Jan 29, 2004 | 08:53 PM
swann79's Avatar
swann79
hehehe... I like this topic. Kinda caught my attention...
In my experience, it has always been beneficial to have the "Big *****"!
Old Jan 29, 2004 | 08:56 PM
Brad Brown's Avatar
Brad Brown
Hey Swann, did your 79 come with BIG *****! er closed knuckle?
Old Jan 29, 2004 | 08:58 PM
swann79's Avatar
swann79
hehe... my 79 has BIG *****... but it's only got a Dana 44... go figure that one out!
That reminds me... check out http://www.trucknutz.com
Old Jan 29, 2004 | 09:01 PM
4WD67F250's Avatar
4WD67F250
it was under my impression that all ford 4x4s and their owners had "big *****"! LOL! sorry, I know it wasn't the answer your looking for but it was just to good to pass up!
closed nuckles have tapered bearings top and bottom and IMO are better than the ball joint type.
Old Jan 29, 2004 | 09:04 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Hands down, the 78' D60. #1 selling point here is the high pinion. The 75' D60 will be a weak low pinion unit, big ***** or not.
Old Jan 29, 2004 | 09:05 PM
swann79's Avatar
swann79
lol... I agree w/ 4WD... I was just being sarcastic
Old Jan 29, 2004 | 09:18 PM
Brad Brown's Avatar
Brad Brown
With all that Big ***** or not, I should swap the 78 non big baller onto the 74 with big ***** Right???
The open knuckle is better than the closed? How about those springs? 2 leaf or multi leaf?
Old Jan 29, 2004 | 09:25 PM
swann79's Avatar
swann79
In most cases, the 2 leaf is better for a smoother ride, the multi leaf for strength and longevity.
Old Jan 29, 2004 | 09:26 PM
77'F-150Mudder
Right.
Yes, the open knuckle is considered better. Springs? I dunno. I would think the multi-leaf set up would give more artiulation. I suppose it all depends on spring rates.
Old Jan 29, 2004 | 09:46 PM
Brad Brown's Avatar
Brad Brown
Thanks a bunch guys!
Old Jan 29, 2004 | 09:53 PM
4WD67F250's Avatar
4WD67F250
yes the open nuckle high pinion dana 60 front is the one you want if you can find one. 78-79 one tons had em and some 3/4s too
Old Jan 29, 2004 | 09:55 PM
Brad Brown's Avatar
Brad Brown
That is the one on my truck 78 sc 4x4 f250......Thanks
