93' f-150
That article should give you some decent ideas on what you need & where to start.
You don't need a new frame, just buy the 4X4 componets you need & it will all fit under your curent truck.
Your problem: you are probably in love with your truck (aren't we all?) and are itching to make her run better.
You may just want to consider a trade-in for a factory 4by4. Buying a new truck is as simple as signing your life away and making 36 easy payments.
I didn't see any mention of prices either, is it cheaper to buy a used 93 4x4 or do the mod???? Between NAPA, the junkyard, and Ford parts, I think you'll be about 1500 to 2000 dollars poorer...but wiser.
