Backup light problem still no work ?
Old Jan 29, 2004 | 12:50 PM
pro3qtr's Avatar
pro3qtr
What am I missing??
New bulbs, switch and still no work.
Never worked since I bought the truck in 97.
Finally decided to take a look at it.
Any suggestions on where else to look ???
TIA
Angelo
Old Jan 29, 2004 | 01:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Get your test light out
Old Jan 29, 2004 | 01:45 PM
pro3qtr's Avatar
pro3qtr
Thanks !! Its raining now !
Guess I will have to shoot the whole wire.
Old Jan 29, 2004 | 01:46 PM
73Custom's Avatar
73Custom
Is it an auto or manual trans? Are all the fuses good?
Trace the wire from the rear light up to the switch and power source. Make sure the wire is in good condition and all connections are clean and tight.
Marty
Old Jan 29, 2004 | 02:01 PM
rainbowATF's Avatar
rainbowATF
1979 F100 302/C4. Had same problem with mine. Ground wire was broken up inside plastic lamp socket. Pushing on it made contact and now work. I'll need to get a new socket eventually. Check power from neutral safety switch. Also there is a 4 pin connector above passenger valve cover that connects to the neutral safety switch: hot, starter, starter, and backup lights. jumping two connectors to hot cause the engine to crank. one connector made backup lights come one. Don't remember details; you'll need to consult a wiring diagram.
Old Jan 29, 2004 | 02:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
I usually start where I have power so that I know I have a good ground for my test light.
-Just my $.02
Old Jan 29, 2004 | 03:24 PM
pro3qtr's Avatar
pro3qtr
see the whole truck is wire taped good and had only 73K for miles and ALL stock.
Trans is a C6.
Problem is the wiring books are not that great back in the day.
My 89 Stang is a Cake walk compared to this ! LOL
Just thought maybe I was missing somthing stupid, guess i will shoot the wire front to back.
Tell U all what I find
Old Jan 29, 2004 | 03:40 PM
grapegravy's Avatar
grapegravy
After a few times of trying to find the shorts in wiring running to the rear of the truck, I made an "as long as truck" jumper wire with alligator clips on each end. Now I find where the power gets to and starting jumping from there towards the non-working electrical component. Makes checking multiple connections in one area from the power supply a breeze. Also good for grounding situations
Old Jan 29, 2004 | 04:10 PM
pro3qtr's Avatar
pro3qtr
Thanks, good idea.
Gonna start at the fuse box and work my way back.
Old Jan 29, 2004 | 04:11 PM
F150daniel's Avatar
F150daniel
my problelm is somewhere between the connector behind the bumper and the tail lights.
pro3qtr's Avatar
pro3qtr
Why is that??
Ok white with purple stripe is the pwr wire from the fuse block to the plug/ switch
Blk with red strip goes to the lights.
thats what I have so far.
Old Jan 29, 2004 | 06:04 PM
300sixowner's Avatar
300sixowner
I have owned my 79 since 92 and my back up lights have never worked, but then I've never missed them much. I just installed driving lights on the back bumper and hit the switch if I can't see where I am going. Not the best solution I'll admit, but it worked for me.
Old Jan 29, 2004 | 06:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
It is best to get the backup lights working because they also serve as a warning device to other drivers that your vehicle is backing or in reverse.
Then of course you have all the old chebies that run around with the backup light on all the time, -but then you have to be backwards to drive a cheby.
BCHauler
Sep 6, 2013 07:15 PM
nomad221
May 1, 2012 12:44 AM
86f250XLT-4x4
Aug 9, 2011 03:18 PM
stevcher
2004 - 2008 F150
Feb 7, 2010 03:14 PM
Skagit
Electrical Systems/Wiring
Nov 16, 2003 08:25 PM
