33 Gallon Bronco Tank In A F-150
OK, this is what I'm thinking. Can you smell the smoke? Anyway...
There was a discussion a week or so ago in the 1987 - 1996 F-Series Trucks Forums about swapping out the rear 19 gallon tank on a F-150 & replacing it with the Big Bronco tank.
This swap has entriqued me & I'm wanting to do it. Hell, I can always afford to carry an extra 14 gallons, ecpecially during the construction season.
This is what I need to know.
I definatly need the big Bronco tank & the straps, thats for sure.
But will my F-150 fuel pump & sending unit work or do I have to get the pump & sending unit out of the Bronco to make my fuel gauge read accurate?
Will the Bronco tank straps bolt up in the place of my F-150 tank straps were, same bolt holes?
The Bronco tank measurements are 31 7/8" X 22 1/4" X 15 3/4"
The F-150 tank measurements are 34 3/4" X 27" X 7 7/8"
