1978 - 1996 Big Bronco
interchange question
Old Jan 28, 2004 | 11:50 PM
btnbronc's Avatar
btnbronc
Question interchange question
What parts can i interchange from a 351w into a 302 (crank, rods pistons, or heads)? thanks for the help!
Old Jan 29, 2004 | 12:22 AM
DW2455's Avatar
DW2455
blocks are the same bore, but the the rods and crank are different, the externak bolt patterns are the same except the 351 intake is wider, the heads will inter change but the 302 heads have to be drilled for the larger 351 head bolts or the 302 block would have to be drilled and taped for the 351's larger head bolts. hope this helps DW
