Sponsored by: Real Truck
Body Mount problems
Old May 17, 2002 | 05:42 PM
Batoutahell's Avatar
Batoutahell
Body Mount problems
I searched back and saw people post about squeaks and creaks coming from the body mounts.
But, I have not seen any fixes for it. Is there any way to get rid of it? Will it harm anything if I leave it?
I hear a kind of creaking noise when backing out of my driveway and sometimes in traffic when taking off. Do you think this is from the body mounts?
Sometimes it also pops a little, that kind of sounds like something hitting the underside of the truck. I am thinking these things are tied to each other.
It has only come on in the last couple weeks since the weather has warmed up.
Any suggestions would be appreciated. I kind of try to avoid the dealer unless it is something serious.
Thanks
Paul
Old May 18, 2002 | 07:20 AM
Yeti's Avatar
Yeti
Body Mount problems
What model do you have? screw? or excab?
The only way to get rid of sqeaky body mounts is to replace them with after market urethane mounts.
Not a fun job to say the least!.
Old May 18, 2002 | 08:24 AM
Batoutahell
Body Mount problems
I have a 2002 F250 Superduty Crew Cab 4x4 v10.
Sorry I should have put that in the original post.
I read in some previous posts that there was a tsb for some earlier trucks (1999), and was wondering what they did to fix the problem.
Thanks
Old May 18, 2002 | 11:35 PM
SVO's Avatar
SVO
Body Mount problems
batoutahell,
local dealer has replaced mine twice,gets worse when the weather heats up I agree that maybe we need to go to after market Im going to try to get ford to pay for it but I dont know if they will or not.
svo
Old May 19, 2002 | 11:07 AM
SKYDAN's Avatar
SKYDAN
Body Mount problems
I too, hear a variety of noises from my 99 V10 F250SD 4x4. One that concerns me is a THUMP from the passanger side floor/door area. Occationally, after it sits for awhile, I'll put it in reverse and hear it. Scared the $#!+ out of me first time it happened, thought I backed into something! I tried to duplicate what had just happened to pinpoint the location of the sound but no luck. When I get tired of hearing all noises I just turn up the tunes. After all, it's a truck! skydan
Old May 21, 2002 | 03:13 PM
harald's Avatar
harald
Body Mount problems
The passenger side/floor thump is related to the air conditioning. You can eliminate the thump by turning the selector to off when shutting down the truck so the a/c won't run when you restart the truck. There's a TSB addressing this issue and it involves changing an accumulator. I can't remember all the exact details, but it had something to do with a duct door slamming too hard.
The body mount problem gets fixed by pulling the cab mount bolts and enlarging the holes. The popping sound you get when the cab flexes is from the bolt dragging on the side of the hole. There's also a TSB for this problem.
Harald
2000 F350 4x4 CC DRW V10 4.30ls Lariat LWB.
Firestone Ride-rite airbags, Rancho RS9000 shocks and Torklift Superhitch.
1998 Alpenlite Pendelton 11'10" camper held on by Torklift tie downs.
Old May 21, 2002 | 05:35 PM
MrRottnDog's Avatar
MrRottnDog
Body Mount problems
