Sponsored by: Kumho
LLS Compressor Noise??
Old Jan 28, 2004 | 07:08 PM
mtuck's Avatar
mtuck
How loud should the air compressor for a four corner LLS system be? I got an '01 Expedition Eddie Bauer just after Christmas and I did notice the noise but now it is really starting to bother me.
My compressor is very loud, from inside the truck it sounds like I have a 20 gallon 2.5 HP air compressor running (it's not quite that loud, but it is very noticable.)
I tried to get a good look at the compressor. I took out the battery, washer fluid resevoir, and was able to unbolt the mounting bracket but the air lines were too short to allow me to turn the unit over and get a good look. I did notice that the compressor has rubber grommets/shims that the mounting screws go through and I did notice that the screws had a lot of play within the rubber grommets.
Questions:
1. Should there be any play within the rubber grommets/shims?
2. If the answer to #1 is "No", then how do I go about replacing the rubber parts?
3. What is the easiest way to access the mounting screws? Is it possible to unhook the air lines without hurting the system? If so, how?
Thanks for any help you can provide.
Tucker
Old Jan 29, 2004 | 08:10 AM
turbo TED's Avatar
turbo TED
mtuck: Welcome to fte of all, if you do a search in the expedition forum for the same thing i wrote the full answer to someone & if you do not find it just write back & i will produce the info then.
keep us informed turbo ted
Old Jan 29, 2004 | 11:18 AM
mtuck's Avatar
mtuck
Turbo Ted,
Thanks for the reply and the welcome, I read your post about the grommet/washer kits you got at the parts stores. My questions is, how do i get at the screws on the bracket? My air lines are too tight to allow me to turn the compressor over and get to the screw heads.
Tucker
Old Jan 29, 2004 | 10:39 PM
turbo TED's Avatar
turbo TED
mtuck: Hey fte buddy the compressor can be loosened from the
brackets & then loose the lines with a twist on the drier & then you can do all your repairs, a word of caution make sure that the
air line are not man handeld & when the repairs are done try doing them with the vehicle at opperating temp.
