Manual Lockers
Old Jan 28, 2004 | 04:45 PM
FordMan190's Avatar
FordMan190
Manual Lockers
Is anyone aware of a company that makes manual locking Hubs for the 98 and newer Vac. Locking system? These Automatics just are not strong enough. Also, Where can I find the auto-locker clips and puller to remove them?
Thanks,
-Phil
Old Jan 28, 2004 | 04:59 PM
WXboy's Avatar
WXboy
Many auto parts stores carry the tools to pull them. If you can't find one, check with your dealer. There is no manual hub replacement for 98-99 Rangers because of the design of the system. You can either replace yours, or convert to the new system used on 2001-present Rangers which doesn't use hubs at all.
Old Jan 28, 2004 | 06:27 PM
BassGuy's Avatar
BassGuy
No hubs at all?!?! Do you think a '96 could be converted to that system? Would it be insanely costly and time consuming?
Old Jan 28, 2004 | 09:13 PM
WXboy's Avatar
WXboy
No, only the torsion bar suspension Rangers can use the "constant engagement" system that is still in use now. A '96 is set up completely differently. You can actually install manual lockers which you might consider.
