The guy that built my upright headers for my pulling truck was also working on a custom frame for a 57 Fairlane. The engine in the car was a 427 SOHC Hemi. The engine was very impressive looking and unlike anything I have ever seen. How rare is this engine, most likely where did the engine originate, and does anyone know any sources to find out more facts about these engines?
The SOHC(single overhead cam) 427 was built back in the late 60's for competition against the Chrysler 426 Hemi. They were based on a 427 but had single cams in each head. They were driven by a 6ft long timing chain. Yes, 6ft. It had a regular timing chain running a stub shaft in the original cam position, then the long chain ran from it to the heads. The stub shaft was needed to keep oil running up to the main galley. All oil is fed thru the first cam bearing area.
The motor was rated at near 650 hp. It was run near 7200 rpm to make that power. It was never truely offered in any Ford product, but you could buy the heads/pieces from your local dealer and build it yourself. It was soon outlawed in Nascar and never seen again. It was run in early 70's in dragsters until the Chrysler design took over and til this day is still run.
All in all it was quite an engineering masterpiece. IF you can find the parts, you too can build one. If you thought a 390 was expensive to rebuild......
Originally posted by Freightrain It had a regular timing chain running a stub shaft in the original cam position, then the long chain ran from it to the heads. for competition against the Chrysler 426 Hemi. They The stub shaft was needed to keep oil running up to the main galley. All oil is fed thru the first cam bearing area.
It would certainly help turn the distibutor and the oil pump too, wouldn't it?
that was a nice website larry, them pics look pretty cool i cant believe that 6 foot chain didnt give any problems at 7500 rpm, but it says there wernt any issues from it.
There were a couple tensioners and chain guides to help things along.
I know DOVE manufacturing made a GEAR DRIVE for this motor. Man, was that a feat.
Someday I'd like to own one of these motors. But, at the cost I dont see it happening to quick.
I have a friend who owns Hayden Proffits altered wheelbase 65 Comet and it has a Hilborn Injected SOHC motor in it, including a 4 spd. COOL car. It has been completely restored nut and bolt.
Actually, the Cammer was never allowed to run in NASCAR. NASCAR had enough of the horsepower wars and put their foot down. As a result, Ford teams didn't boycott NASCAR the way the Mopar teams did when NASCAR wouldn't allow the Hemi, but they did get very lax about showing up for races for awhile after.
Hard to imagine any such thing in today's NASCAR.
The Cammer would be a lousy street engine. As mentioned, almost all the HP and torque comes above 4000 RPM.
The reason Nascar wouldn't allow the SOHC was to keep the Europeans out of it. The SOHC was introduced in 65, and the HP war in Nascar went on for quite sometime afterwards. The Shotgun Hemi was Ford's answer to Nascar's not allowing the SOHC. The SOHC was offered thru the dealers as a complete crate engine in addition to the individual parts. It was campaigned extensively in the mid to late 60's in Topfuel dragsters and the early funny cars.
Originally posted by Ratsmoker I thought the chain was 8 feet long?
6 or 8 ? I can't recall, but either way it was too long. You had to really know your stuff to degree the cams to compensate for the stretch at 7000 rpms though
So NASCAR outlawed OHC motors across the board to keep it all American?
Funny, now they are letting Toyota in. With all the changes taking place, I decided it was a good time just to quit following it. I don't like rice burners in NASCAR - I hate the "Lucky Dog" rule, and I don't care for any of the new drivers. Now they changed the points rule because Kenseth (and Ford) won it last year with consistency.
NASCAR hates it when Ch*vy loses. This has been going on for years.
Yea, what a difference 30-40 years makes.( letting Toyota in) while somethings change , others stay the same ( Chevy's been Nascar's favorite since the early 70's) I wish the good old days would return, when Ford and Mopar and the 426-427's were king.
