overheating at -40
Old Jan 28, 2004 | 12:27 AM
Lessica Jake's Avatar
Lessica Jake
Talking overheating at -40
I have an '84 F-250.
In the last 6 months, I have replaced the water pump, thermostat, guage controller and radiator hose.
It is -40 celcius today, and with no winter front, my truck is overheating. If I run it over 80km/hour for more than maybe 6 or 7 minutes, it starts to smell hot. doesnt take too long to cool down after i drop my speed, but at these temperatures it should be nowhere near overheating. most people cant even get their vehicles to run warm.
i've run out of ideas as to what could be wrong with the thing. any suggestions?
Old Jan 28, 2004 | 01:38 AM
greasymonkey's Avatar
greasymonkey
.........sounds like you could almost leave it alone for now!!!!..........................I suppose you've checked wether the rad is flowing?
Old Jan 28, 2004 | 06:11 AM
pnose's Avatar
pnose
Did you use a ford or international tstat?If not that could be your problem.It can also be a pita to get the air out of the cooling system.
Old Jan 28, 2004 | 08:30 AM
bilder12's Avatar
bilder12
Is it actually overheating or are you seeing the effects on the guage? Carefully remove the radiator cap and insert a pencil thermometer and see what ya got.
Old Jan 28, 2004 | 12:08 PM
Lessica Jake
i expect that the tsat is a ford part because the ford garage did it. i am seeing the effects on the guage for the most part, but if i let it go, it smells hot, so that would tell me that the guage is not the problem.
Old Jan 28, 2004 | 10:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Two items can cause this, not enough antifreeze and the radiator is slushing not letting the water circulate, or a failing fan clutch.
I had electric fans on mine for a while and it would drive around town fine all winter with no fan at all. But hit the interstate and after about 10 miles at 50+ MPH and the engine temp was on the rise. Kick the fan on and it dropped right back down.
I have my stock fan back on now but it is not making enough noise while running fast, and my temp is climbing out on the interstate again. I am positive my fan clutch is toast causing the problem.
If I had an electric fan that was reliable I would leave that fuel sucking stock fan in my garage.
Old Jan 28, 2004 | 10:21 PM
Lessica Jake
i wonder about the fan, because i can never tell if its actually running or not. i've been told that when it kicks in i'll know, but i havent noticed it yet. is there an easy way to tell if the clutch is bad?? i've got a couple spares, but i know they're a pain to change, so i'd like to know for sure before i do that.
Old Jan 28, 2004 | 10:48 PM
Dave Sponaugle
If you do not hear it running it probably isn't. When mine was working right it would kick out at about 65 MPH and kick back in at about 55. You could definitely hear it kick out and in as the engine got a lot quieter when it was out.
Old Jan 28, 2004 | 11:43 PM
Lessica Jake
thanks, i suppose i'll try changing that & see what happens.
Old Jan 29, 2004 | 05:46 AM
pnose's Avatar
pnose
If you already got a spare fan and clutch that would be a good place to start.Remember there is a REVERSE tread on that nut.
Old Jan 29, 2004 | 07:23 PM
rancherman84's Avatar
rancherman84
i discovered mine was bad last summer,not because it was overheating but my a/c wasnt very cold.when i installed the a/c gauges they showed me that the air flow thru the condensor was slow,grabbed the clutch(engine off of course) and it spun like it crazy.replaced it and every thing was ok.
clinkfield
29
Aug 16, 2013 03:54 AM
83fordcolebrook
Jun 14, 2010 06:58 AM
pullt1
1997 - 2003 F150
Jan 3, 2007 04:21 PM
thegman1000
1997 - 2003 F150
Jun 15, 2003 12:17 AM
cakewalker
Aug 28, 2001 01:38 AM
