Sponsored by: Real Truck
Window rattle
Old Jan 27, 2004 | 08:24 PM
gus515's Avatar
gus515
Window rattle
I have a 2003 F250 Lariat 4 door 4 wheel drive longbed. I am having a problem with the driver window. I have had it in 3 or 4 times for this problem. It rattles over certain roads, and the motor does not hold up all the way. It never comes down enough to create a visible crack. There is an audible shifting down of the window after you roll it up all the way. None of the other windows do this. I have had my wife drive the truck over the same roads at the same speeds while I sit in the other seats one by one to see if any of the other windows rattle and they do not. I say rattle for lack of a better description, but it is not what I would normally call a rattle. A rattle to me is some pebbles in a tin can. The dealer has supposedly "fixed" this each time, and within 100 miles the problem is back. Any suggestions?
Old Jan 28, 2004 | 03:31 AM
Monsta's Avatar
Monsta
Sit. Stay.
Moved to SD forum for a better chance of responses.
Old Jan 28, 2004 | 07:24 AM
jetjock16's Avatar
jetjock16
tighten the striker plate of that door.. ie.. move it inward, tighten the pressure on the door when closed.. tons of us have dealt with this... many posts in past
