straight axla conversion
Old Jan 27, 2004 | 07:42 PM
82f1504x4's Avatar
82f1504x4
i have an 82 f150 and i would really like to swap out the ifs for a straight axle i wasthinking i could use the same year truck but possible f250 if any one knows how to do this or nows what axle to use it would be great help
thanks
justin
Old Jan 27, 2004 | 09:15 PM
bremen242's Avatar
bremen242
You'll have to use a Dana 44 high pinion from a 78-79 F-150. you can use back to a 73 f-150, but they are low pinion. They don't regular many mods.
F-250 or F-350 axles will not fit without severe mods.
Old Jan 28, 2004 | 12:45 AM
stangboy_82's Avatar
stangboy_82
there's also a company I think it's fabtech that makes the kit for doing that I think it's a lift kit also
Old Jan 28, 2004 | 01:15 AM
fishmanndotcom's Avatar
fishmanndotcom
i discourage those b/c they just want your money. I bought a D60 front out of a DRW F350 for $1000...came with everything including tires/rims, shocks, steering, track bar, brakes, 4wd hubs, and leafs(check out my gallery). That's what you need to look for. don't go pay $2500 for a kit when you can do it all for a heck of a lot less than $1000. A D44 will prolly run ya $400-$500. and if ya need any parts we have plenty laying around over here...give me a holler!
-jason-
Old Jan 28, 2004 | 04:59 PM
BLaCkSiLo's Avatar
BLaCkSiLo
hey, how about an 84 f-250 straight axle conversion? what kinda hoops would i have to jump through and what would be a good donor truck?
thanks,
James
Old Jan 28, 2004 | 08:35 PM
bremen242's Avatar
bremen242
Easy. get a donor F-350 85.5-97 F-350 4x4 and get to work. everything bolts up.
I think 92 and up have balljoints instead of king pins. I don't know if that is good or bad though.
Old Jan 29, 2004 | 05:55 PM
82f1504x4's Avatar
82f1504x4
i am not looking for a kit of any kind i want it to be built how i want it and all im going to rebuild the whole thing locer axles and all thanks a lot
Old Jan 29, 2004 | 09:05 PM
mustange70's Avatar
mustange70
Ball joints are way better then kingpins in this instence.
Old Feb 1, 2004 | 02:36 PM
fishmanndotcom
??????????????????????????? since when?
just like Bremen said...everything bolts stright up to 3/4 and up...even the trac bar surprisingly!
1/2's have coil springs and are a lil trickier!
-jason-
Old Feb 1, 2004 | 05:37 PM
bremen242's Avatar
bremen242
fishmann:
when you remove the passenger pivot bracket, the trackbar mount goes in its place, right?
btw, which are better? I know kingpins are a b%4ch to change, but being they are steel, they probably take a little more abuse?
