dakota crossmember
Old Jan 27, 2004 | 05:59 PM
medicman14420's Avatar
medicman14420
Question dakota crossmember
well it has been ordered from industrial chassis for my 1954 effie.
I have a donor truck located but it has a 4cylinder and I was curious if that was going to cause a problem or are the arms and suspension going to be the same. if any one has a instructional video or diagrahm I would appreciate it if I could get a copy. I will be using a 400SBC bored .030
Old Jan 27, 2004 | 08:46 PM
DS02F250's Avatar
DS02F250
I did a Dakota IFS on my '59, but it came out of a '88 Dakota that had a 3.8L V-6 in it. I have a 302 SBF in mine, so the weight difference b/t what the 4-banger Dakota can handle vs. the 6-shooter could be significant enough to research. You might ask IC. It may just be a matter of installing stiffer springs, but I'd check with them first, or research and determine if the IFS components were the same for the 4 and 6 cylinder Dak's.
I have a link on my gallery that shows the IFS install...
Old Jan 27, 2004 | 09:27 PM
medicman14420
ds59f100 I was looking at your install and was curious about the motor mount positions. and did you have any trouble with the brake setup. I am going to use the dakota setup on the firewall
Old Jan 27, 2004 | 09:32 PM
DS02F250's Avatar
DS02F250
Hmmm, not much help there: I have a Jeep power booster/dual master cylinder setup on mine. We did, of course, have to re-plumb the brake lines for the front disc brakes 'n all, but that's typical with a new IFS clip install.
Sorry, can't help ya on the Dak brakes/firewall part...
Old Jan 28, 2004 | 12:18 AM
Homespun91's Avatar
Homespun91
Medicman,
So far as I have been able to determine, all the Dakota IFS pieces (for the appropriate years) are functionally identical (see the Dakota threads or Kenny's suspension article at the top for specific year differences). The springs do vary for engine type & may require substitution; however, they are relatively cheap, even brand new. Ind. Chassis does recommend only donors with power racks. I ** T H I N K ** this is simply because of the installed application, & the A-arms, etc. are identical between power & non-power rack vehicles. I have not definitively confirmed this, however (& really wasn't too interested, since nearly all of the donors I found were power-equipped).
As far as the instructions go, the ones that came with my kit were very decent. As usual, measure twice, have a trusted, sober friend measure again, then cut carefully.
As far as the brakes go, I think you are on your own. The rotors, calipers, etc. are certainly good enough sizewise. You might check with I.C. as to whether they have tried the Dakota master/booster. They make a kit to place a master setup on the firewall, think it was a C***y master, though. Otherwise there are any number of aftermarket setups for the stock master location. Hope this helps....
Kurt_Laughton
Ohio Chapter
Aug 28, 2013 04:02 PM
go6.0go
Jan 29, 2009 08:51 PM
fabmandelux
Oregon Chapter
42
Jan 2, 2007 11:27 PM
mustange70
Canadian National Chapter
13
May 19, 2006 01:21 PM
pwrstk01
Feb 15, 2006 08:38 PM
