Got my Isspro tranny temp gauge with pillar pod all hooked up except I am not sure where to hook up for power for the gauge, the back lighting is all hooked up.
I searched all over the net but none of the wiring or suggested hook up points match what I am seeing on my truck. Anyone got a suggestion?
Several locations for 12 VDC, one 12 vdc spot:
Grey and red wire near the lower front right of the dash panel. It has a piece of factory tape on the end of it. I believe it is just behind the OBII connector. It may be wrapped with two other wires. Otherwise use your meter to find another.
