I was changing the air filter in my 2001 ps and I broke the darn clip that holds the top down
I have it fixed for now but was thinking since I need to replace it that maybe I would replace it with something other than oem. Would apprecate to hear from anyone that has gone with an aftermarket box and filter and website where I could check them out or the thread where it has been covered.
Welcome to the forum, Buckie!!
You've asked a question that is brought up frequently. There are a number of opinions on the subject, but I'd say the majority of aftermarket intake purchasers choosing the TYMAR.
Pour yourself a tall cold one, do a search for TYMAR, and enjoy your reading.
Question about the tymar system for you guys. I travel alot of roads that are dusty. Is this system ok to filter out the dust properly? Is it like the K&M system where you clean your filter and don't replace it ? Thanks for any feed back.
Ed, here's my read on it. The filter used in the TYMAR flows so much air, and filters so well, I replace my filter because it looks dirty, not because it isn't doing the job any more. Dale insists the filter works well enough when it's too ugly to look at, that you've still got a lot of miles left in it. The filter element is replaceable, not reusable like the K&N.
Oppy- what are you basing it on when you say the Ford AIS filters best? I'll give in on the fact that it looks stock, but I'll need some data for the "filters best" part. Also, while you're coming up with data, tell me how much air it flows compared to a TYMAR.
We've been down this road before, Quad. Check out TDS, there was a lengthly discussion with posts by a Donaldson engineer, that stated the AIS as a whole flows better than the Tymar.
I know you don't believe this, but Buckie was asking for opinions and I gave mine.
In fact, here's exactly what I said in a previous thread:
Before I made my decision, I looked at the other systems, and ultimately I decided that the AIS flows well, filters great, looks stock, doesn't create warranty issues and was reasonably priced - a no-brainer as far as I was concerned.
That's an interesting piece, and was obviously written by someone with strong credetials.
The filtering efficiency of the new AIS is 99.9%+. The system will load approximately 900 grams (just about 2lbs.) of dust to the trip of the Filterminder. With a 99.9% efficiency rating this would mean that less than 1 gram of dust would pass through the AIS to the clean air side. Competing with this new AIS on the market today, are various aftermarket induction systems that utilize washable filters. I have tested some of these filters and found their filtering efficiencies to be as low as 70%. This would mean on a 900 gram dust load, 270 grams (just over 1/2 lb.) of dust will be ingested into the engine. Now this would be devastating to any engine and more so to an engine with a 100,000+ rpm balanced turbo charger.
(Italics are mine)
He has stated that the new AIS intake filters better than aftermarket intakes that utilize washable filters. I think the filtration numbers for the Donaldson filter used in the TYMAR are the same as the AIS.
