Bronco II Ford Bronco II
keyless entry
Old Jan 27, 2004 | 02:12 PM
Bgrossenbacher's Avatar
Bgrossenbacher
keyless entry
The electric locks on my 90 BII work well and I wanted to be able to lock and unlock the truck using a remote device.
I bought a kit on eBay that has everthing I need and a wiring sheet with what goes where.
What I donot know is where on the truck to begin hooking up the kit. In particular a place where a constant hot wire is available and access to the door locking wiring so I can get it all hooked up in 1 area.
Thanks for a great forum.
Old Jan 27, 2004 | 07:33 PM
Ken00's Avatar
Ken00
You should be able to get a hot wire (bk/w)and the controls (pk/lg & pk/y) in the door.
Old Feb 4, 2004 | 12:33 PM
Bgrossenbacher
Thanks for the response.
I looked in the door this past weekend and was not sure where to mount the control box. so I looked under the dash. assuming the color scheme for wiring is the same, I found a capped plug with the three colors indicated and 3 additonal wires, 2 green combos and a white-black.
Is this where a factory keyless control box would have been installed? can I use this instead of connecting to the wires in the door? What about a ground?
Thanks for any help
Old Feb 5, 2004 | 03:25 PM
Ken00's Avatar
Ken00
I don't think BII ever came with keyless entry. You can ground to anyplace on the body.
