Sponsored by: Real Truck
dana 50............need some quick info!!!
Old May 29, 2002 | 06:59 PM
4x4x4x4's Avatar
4x4x4x4
Old May 29, 2002 | 10:32 PM
redranger1's Avatar
redranger1
[updated:LAST EDITED ON 29-May-02 AT 11:52 PM (EST)]does anybody know if the 4 : 10 gears will fit on the 3 : 73 carrier assembly of a ifs dana 50??? also, does anybody know how interchangeable the parts are between the ifs dana 50 and the 8 bolt ifs dana 44? if anybody has any info on these two front ends i would appreciate it if they could *** it along. thanks.
-nathan
Old May 29, 2002 | 10:46 PM
Bronco2Mudder's Avatar
Bronco2Mudder
I believe all Dana's carrier split is at 3.73 or higher. You should be fine.
Also, from what I understand, the D50 and D44 IFS share the same guts, just different outers (knuckles out). The inners are still D44. The D50 gets the 1 ton outers.
Chris
Old May 29, 2002 | 10:56 PM
redranger1's Avatar
redranger1
thats it what i was thinkin about the carrier also. i am not sure about the guts part though. i have a 44 third member and a 50 third member and when you compare the 2 the 50 has more space cut out fer the ring gear. also the 44 has ifs 44 cast inside of the third member, the 50 doesnt. thanks fer the quick response man, i appreciate it.
-nathan
Old May 30, 2002 | 08:55 AM
FortyFords's Avatar
FortyFords
Nathan !
I can see gears turning !!!He He He
What are you up to Nathan?
no fair, If you don't tell!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old May 30, 2002 | 10:41 PM
redranger1's Avatar
redranger1
oh.....well.....im just.....ummm.....workin on the pullin truck. yea, thats it!
-nathan
