Ffv Module In Fuel Line
Old Jan 27, 2004 | 09:32 AM
navion's Avatar
navion
Question Ffv Module In Fuel Line
DOES ANYONE KNOW WHAT IS THE RESULT WOULD BE OF BYPASSING THE FFV MODULE IN THE FUEL LINE BETWEEN THE FILTER AND THE ENGINE? ON A MAZDA B3000 1999. Thanks in advance.
Old Jan 27, 2004 | 03:47 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I would guess a constant CEL and the PCM running in fault mode.
Old Jan 27, 2004 | 04:02 PM
navion's Avatar
navion
Thanks Ken for the reply.
Do you happen to know what function the FFV module has?
Is it to reduce the fuel pressure from the regulator on the pump?
Thanks
Old Jan 27, 2004 | 06:58 PM
Ken00's Avatar
Ken00
It detects the E-85 and the PCM uses it to change the timing & air/fuel ratio.
Old Jan 27, 2004 | 07:34 PM
navion's Avatar
navion
Where can I find out what the E 85 is? I'm guessing that it has to do with fuel pressure changes from unleaded to ethanol mix.
Anyway, thanks for taking the time to reply to a newbie.
Old Jan 27, 2004 | 07:46 PM
Ken00's Avatar
Ken00
Flexible Fuel Vehicles can run on fuel ethanol (E-85) or on unleaded gasoline. The flex fuel sensor detects the alcohol content of the fuel to determine what type of fuel is being used.
