Offroad & 4x4
Full Hydro Steering
Old Jan 27, 2004 | 01:20 AM
ivanribic's Avatar
ivanribic
Full Hydro Steering
Been planning to go full hydro on my Dana 60 front. I have read about everything I can find about doing this and it all makes decent sense to me. The problem I'm running into is this: All the guys running this sytem are using crazy rock crawling front ends without leaf springs. I can't seem to find a way to build a frame for a double ended ram and have my tie rods clear my leaf springs. I am wondering if I can use my regular tie rod mounts for steering, rather than the steering arms.
Any ideas on this one? It's confusing the hell out of me.
Old Jan 27, 2004 | 01:53 AM
Fordboy 72 F-100 4x4's Avatar
Consider finding a cross over steering setup that will relocate your tie rods. Or Try to find a set up that with one sided ram that will mount in place of a steering stabilizer to the drag link.
Also these setups are used on rock crawlers to give them alot of power in the steering. They can virtually move the whole truck with this. But notice that none of these guys really drive these rigs on the street. When you are on the freeway or at speed the steering loosens up. The rams are way to powerful and will amke driving a chore
Old Jan 27, 2004 | 03:33 AM
82F100SWB's Avatar
82F100SWB
Also, high rpms can cause cavitation in the pump, and result in a complete loss of steering control. If the truck is going to see alot street duty, just for safety's sake, PLEASE just run a hydro assist setup. I for one don't want you, or me to end up dead because someone overspun their pump, blew a hose, ETC. and lost control of their steering.
On something as important as a steering system, if it's gonna be a pavement pounder, a mechanical backup is a necessity.
Old Jan 27, 2004 | 04:42 AM
Idiomaticman's Avatar
Idiomaticman
i have a link for you....its great, you gotta love those pirate4x4 guys, think they know everything.
http://www.pirate4x4.com/forum/showt...hreadid=215086
great stuff in there once you get around all the flaming....god i hate all that flaming...it hurts...
Idiomaticman
Old Jan 27, 2004 | 03:28 PM
ivanribic's Avatar
ivanribic
I've done a lot of reading on pirate4x4 about the hydro steering though this thread was new to me. There seem to be just as many people who are for it as are against it. I'm not concerned about the safety of a hydraulic system . . . I trust my life to it every time I fly. What DOES worry me a bit is the cavitation of the pump at higher RPMs. I was not aware of that happening, a definite problem unless you run an electric pump.
I like the idea of it for being able to lift a truck any amount and not having to screw with anything but extending hoses. I thought it would be a lot easier to handle offroad than a crossover system. Most of my driving will be on the street but several of the guys who are using Sean's setup are running on the street and say it works great. I figure it can't wander any more than my stock steering.
My question was more if anyone knows of a good way to mount the ram on the axle with leaf springs. If it seems too difficult or, of course, too dangerous I'll scrap it and go to crossover steering.
Old Jan 27, 2004 | 03:35 PM
proeliator's Avatar
proeliator
Ivan, I haven't done it myself, but thats because I haven't seen the need. A well designed cross over steering set up with ps will easily steer and move even 44s over rough terrain. Hydro is cool as hell, but I wouldn't bother with it on our full sizes that aren't dedicated rock crawlers. My understanding is that for you to go hydro, you'd have to go hi-steer anyways to lick the clearance problems you've found. So, unless you want the ability to move boulders with one finger on the wheel, try the x-over first.
Old Jan 27, 2004 | 04:35 PM
JeremyH's Avatar
JeremyH
http://www.pscpowersteer.com/
Contact Tom.......he can help you out.
Old Jan 28, 2004 | 12:13 AM
85351ho's Avatar
85351ho
full hydro=broken ford knuckles=dedenbear or welderboy=$$$$
Old Jan 28, 2004 | 12:16 AM
Idiomaticman
you know ho, that didnt make any sense to me....can you put that in english for me haha
Idiomaticman
Old Jan 28, 2004 | 01:07 AM
fishmanndotcom's Avatar
fishmanndotcom
lol basically it is more expensive than it's worth unless you are competing in a rock crawl competition
-jason-
Old Jan 28, 2004 | 01:52 AM
ivanribic's Avatar
ivanribic
It's taken me a while but it's slowly coming together. I've gathered all the information given me on FTE and compiled it to one simple equation:
IVAN X WANTS = $$$$$$$$$$
Okay, so I'll scrap the full hydro idea for now and do crossover. I guess if Pro and Ho don't need it for 44's I won't need it for 40's. Still would have looked damn cool.
Got a question then, since you guys rained on my hydro parade. I see a lot of guys with crossover steering also running a trac bar (think that's what it is). What is the purpose for it? I notice that Pro is not using one.
Old Jan 28, 2004 | 07:47 AM
85351ho's Avatar
85351ho
the trac bar is to keep the axle from moving side to side, but with thicker and stiffer lift springs, side to side movement is not nearly as bad as it is with thin stock two leaves up front. so it is not much of a concern....with heavier springs and crossover, a trac bar will just limit flex a bit, and make the handling a bit looser on the road....i hope that made sense, im still trying to wake up
Old Jan 28, 2004 | 10:18 AM
fishmanndotcom
so you think i should take mine off? (trac-bar)
-jason-
Old Jan 28, 2004 | 10:53 AM
ivanribic's Avatar
ivanribic
So it's really more critical for a guy running coil springs up front. Thanks for the explanation Ho.
Old Jan 28, 2004 | 12:49 PM
proeliator's Avatar
proeliator
Yup, that about covers it...I've had zero problems with mine (or lack thereof). Basically, as long as you have enough other beefy stuff locating that axle you are good to go.
