i am getting ready to buy a 6" skyjacker lift what i dont know is i dont want just the basic lift i want the whole package but which 6" is it can anyone give me a part # for the total package deal
I have a 6inch Pro comp lift on my 95 Bronco (cardomain.com/rudedogii). It didnt come with every thing, but I found that out latter. I took off the lift blocks and put Skyjacker soft ride leafs, better! It didnt come with longer brake lines either and I didnt know it needed them till I was installing the new leafs. The truck was lifted off the ground and I could see the brake line streach before we even started to work on the truck.
It also dosent come with extended bump stops or sway bar extentions. I put a 6inch Skyjacker Class 2 lift on my Ranger it came with every thing but rear bump stops. Buy the rear leafs
springs way better than blocks. I want to take off the 6inch lift off my Bronco and install the 8inch Skyjacker lift. Would you be interested in buying my 6inch lift? Springs, brackets, extended radius arms, and pitman arm. For about $800.00? The rear leafs cost me about $325.90.
A 6inch Skyjacker class 2 lift kit with rear leafs and hydro shocks part #286BKS-A check Skyjacker.com. Good luck
thats pretty good do you have a body lift to or just suspension im sticking to skyjacker though i am pretty sure that im getting the 6" lift but if i do get one im getting a body lift to but im still thinking about the skyjacker 8" how much is the 8" with everything and the 6" with everything from skyjacker
No body lift on my truck.
I dont know the prices for a Skyjacker lift but you can find out on line at Four Wheel Parts, thats where I get most of my parts.
