H.P rating
Old Jan 26, 2004 | 08:45 PM
RichardMaerz69's Avatar
RichardMaerz69
H.P rating
79 351w stock bottom portedheadsD8oEheads gasket matched,edelbrockstealth intake,holley 650,long tube headerswhat would my h.p roughly be.
Old Jan 26, 2004 | 10:09 PM
prostocktom's Avatar
prostocktom
You sure your not running a Weiand Stealth intake ?? That's a real low cmpression engine and with no cam in it I would guess maybe 200 horsepower. Your ported heads with no cam and low compression are most likely killing your air speed in the ports. Get you a good cam in there and I'll bet you can get into the 250-260 range with everything else you have.
Old Jan 27, 2004 | 05:30 AM
RichardMaerz69
sorry about that I gave you the wrong info ,it's an edelbrock streetmaster,as for the cam don't know whats in it p.o said the guy he bought it from did some work to it.BTW it came out of a3/4 ton van if that means anything.
Old Jan 27, 2004 | 10:39 PM
fordeverpower's Avatar
fordeverpower
i figure you have about 210 hp right now. i agree that a cam would help quite a bit.
