Cold truck
Old Jan 26, 2004 | 08:34 PM
Bimmer ese's Avatar
Bimmer ese
Cold truck
Well, it's freeeeezing cold here in good 'ol Oklahoma (around 20 deg fahrenheit). Also noticed the temp needle staying around the low side of the gauge. The needle would not get past the C mark of the gauge. Yesterday, the truck ran fine....needle was at N of NORMAL. Sadly, the truck has been like this since new. The heater did put out hot air, and flushed the cooling system a few weeks ago.
Any ideas on what would make the truck run really cold? Thermostat? I figured this could be killing my MPG. Currently getting around 14mpg.
Cheers,
Dan
Old Jan 26, 2004 | 09:37 PM
frederic's Avatar
frederic
Re: Cold truck
Sure thermostat is a good place to start. Inexpensive to fix. Also, your fan clutch might be stuck, so the fan is always spinning at engine RPM. That would hurt mileage too.
You might not have enough fluid.. some of the temp sensors are mounted in places where a lessor amount of fluid will cause an incorrect meeting.
Does your interior heater work? If not all that well, thermostat is the best place to start.
Old Jan 26, 2004 | 10:12 PM
Bimmer ese's Avatar
Bimmer ese
The heater works great. Haven't lost any fluid since I changed the antifreeze/hoses. In regards to the fan clutch, the fan seems to be on all the time. Is it suppose to act like an electric fan, soming on at certain temperatures?
Dan
Old Jan 26, 2004 | 10:22 PM
frederic's Avatar
frederic
Dan
The fan clutch is a mechanical device, working much like those old round honeywell thermostats we used to have on our walls for the heating system of the house. Inside, its essentially a big spring that changes friction when the temperature changes.
Hotter, more friction, fan spins closer or at engine RPM, cold, it kinda just spins at some random speed significantly less than the engine RPM. It will always spin since there is some friction at a minimum.
The electric ones have a temp sensor, which is really just a switch. Over a certain temp, the electric fan gets electricity and spins, below that temp, the electricity cuts out and the fan stops.
Glad you're not losing fluid... depending where the leak is it can get nasty. Maybe you have air in the system? If you hvae decent heat, probably not, it usually collects in the heater core.
Old Jan 28, 2004 | 07:12 PM
johndem's Avatar
johndem
Trailering
has it ever been that cold there before? did you have the same problem? try putting a piece of cardboard in front of the radiator. as you're moving too much cold air is moving through the radiator, not allowing the engine to heat all the way up. the cardboard restricts the air flow allowing the engine to heat up. just remeber to remove the cardboard when the spring comes and don't block the entir radiator- maybe just 1/3.
or maybe the gauge/sending unit is having problems.
john
Old Jan 28, 2004 | 09:00 PM
Bimmer ese's Avatar
Bimmer ese
john
Hmm...forgot about the cardboard trick. I too, am thinking it's a sending unit problem. This afternoon, the needle reached the N of NORMAL, while this evening, it barely touched the N of NORMAL. Who knows? The next time it is cold, I'll try the cardboard trick.
Dan
rhildebrand
17
Aug 7, 2014 07:32 AM
GuitarJesus
13
May 21, 2014 08:33 AM
JBSIXGUNS
Oct 21, 2013 07:06 PM
VONxRUBENxLA
Oct 6, 2011 10:29 AM
Gus00
Dec 21, 2005 10:22 PM
