I have an X 2000 limited. The headlight **** to turn them on and off is broken and falls from the dash often. I went to the dealer and they only sell the **** and switch together for 90 dollars plus 100 installation.please advice on a cheaper alternative.
Maybe you can get the billet replacements for cheaper. I know they have them for the heater *****, but not sure if they have it for the light ****. But they are the same as the light ****. I bet that the billet heater ***** are cheaper then 90 dollars.
But the weird thing is that when I was test driving to buy mine 2000 X Limited, All the ones I drove had lose light ***** as well. Now mine is a bit loose but it makes an annoying squeaking nose when I go over a pot hole. Even the heater ***** are getting a little loose. If you need some web sites that carry the billet ones let me know.
Mine broke too. I flicked it to the left and it flew out the window. Luckily it was under warranty. I just wanted the 50 cent **** and they had to replace the entire switch for $70 or so. I bet you could find a X or super duty in a junk yard somewhere and just pull the ****...if not take the entire switch??
Make : FORD Model : EXCURSION Year : 2000
NHTSA CAMPAIGN ID Number : 01V075000 Recall Date : MAR 02, 2001
Component: EXTERIOR LIGHTING:HEADLIGHTS:SWITCH
Potential Number Of Units Affected : 74000
My wife went to a dealer here in San Antonio,Jordan Ford. They told her to "forget it" ,that it was a internet rumor. Is there anything more official or " proveful"that we can take to the dealership next time.
Thank you
Subject:
Safety Recall 01S09 - Certain 2000 Model Year Taurus, Sable and Excursion Vehicles - Headlamp Switch **** Replacement
AFFECTED VEHICLES
Certain 2000 model year Taurus and Sable vehicles built at the Chicago Assembly Plant from October 8, 1999 through December 6, 1999.
Certain 2000 model year Taurus and Sable vehicles built at the Atlanta Assembly Plant from October 8, 1999 through December 4, 1999.
Certain 2000 Model Year Excursion Vehicles built at the Kentucky Truck Plant from October 8, 1999 through October 30, 1999.
SAFETY CONCERN
In some of the affected vehicles the headlamp switch **** may fracture or fall off the headlamp switch.
SERVICE ACTION
The dealer will replace the headlamp switch **** assembly. This must be done on all of the affected vehicles.
