Sponsored by: Real Truck
Replacing corner lights
Old Jan 26, 2004 | 02:48 PM
scooby3_4's Avatar
scooby3_4
how do you remove the corner lights on a f250 i got some new clear one ready to go on but dont know how to change them
Old Jan 26, 2004 | 03:06 PM
fn250's Avatar
fn250
there should be some screws below the light ... two if I remember correctly ... take those out and the corner should slip right out ... granted you've already unpluged them from the harness
Old Jan 26, 2004 | 03:32 PM
McCrusty's Avatar
McCrusty
Once the screws are removed the light will still be stuck in place. There are two "studs" (for lack of a better term) on the back of each light fixture (look at the back of your replacements and you'll see them). Each stud snaps into a rubber/plastic gromet to help hold the light in place. So, once the screws are removed you'll still have to pop the light out...and it can be a soild hold so you'll have to pull a little bit.
Old Jan 26, 2004 | 08:57 PM
scooby3_4's Avatar
scooby3_4
Thanks guys was not sure i was doing it right i will just need to pull harder then.
Old Jan 27, 2004 | 09:08 AM
CmprSpecial's Avatar
CmprSpecial
My owners manual has the instructions with pics...
