85 f150 timing
Old Jan 26, 2004 | 12:05 PM
slifer's Avatar
slifer
85 f150 timing
I just swapped in a duraspark II, do I still want my timing at 10 degrees? I thought I read something about it only being set at 6 degrees w/ the duraspark. Thanks in advance.
Old Jan 26, 2004 | 04:22 PM
mopar's Avatar
mopar
ALL 302 AND 351 (INCLUDING 351 4V H.O.) TIMING IS SET AT 10 DEGREES BEFORE TOP DEAD CENTER THAT I'VE SEEN, FROM 1980-1991. WHEN ADDING AFTER MARKET IGNITIONS (JACOBS,MSD MALLORY ETC.) YOU USUALLY ADVANCE TIMING. I DON'T REMEMBER ANY FORD TRUCKS FROM 1979-1993 TO BE LESS THAN 8 DEGREES BEFORE TOP DEAD CENTER.
Old Jan 27, 2004 | 09:37 PM
GregoryB's Avatar
GregoryB
You need to check your tags in your engine compartment for the " calibration code"..... There are some 302s in 1983 that are set at 6 degrees BTDC... for 1985-6 some are 8 and some are 10 degrees....
That code will be something like ' 5-51D-R00'..... post it and I will look up your numbers...
Maybe you need to look on the vehicle you took the DuraSpark from ?
Old Jan 27, 2004 | 10:05 PM
fordeverpower's Avatar
fordeverpower
10 is good 6 btdc is worthless.
Old Jan 27, 2004 | 10:42 PM
GregoryB's Avatar
GregoryB
I mentioned the 6 on the 1983 since it was asked about and Mopar said he had only seen the other setting... to give others a ' heads up ' that they need to look up in the book before assuming they should use the 10 degree setting....
Old Jan 27, 2004 | 10:51 PM
fordeverpower
more power and better fuel economy with 10 btdc or use 6 btdc like a professional mechanic.
Old Feb 2, 2004 | 04:41 PM
mopar's Avatar
mopar
Thumbs up
GregoryB is correct on checking the numbers on engine first. This will ensure correct timing for each application, since there are different calibrations. But 10 degrees BTDC is a general specification and applys to most, (not all), and is a good starting point.
Old Feb 2, 2004 | 04:49 PM
mopar's Avatar
mopar
Smile
Gregory B is correct, since there are different calibrations. 10 degrees BTDC is the general setting on most applications, and is a good starting point. Remember, the question was for a non stock application!!!!!!! 10 BTDC is a good starting point. Advance Or retard timing as needing.
Old Feb 2, 2004 | 07:51 PM
fordeverpower
whatever!
Old Feb 3, 2004 | 02:21 PM
mopar's Avatar
mopar
Originally posted by fordeverpower
whatever!
YEP!!!!!!!!!!!!!
LARIAT 85
Feb 23, 2014 03:29 PM
Rusty_S
Feb 22, 2014 04:17 PM
Jhengl
Sep 24, 2009 04:32 PM
LARIAT 85
May 11, 2009 01:48 PM
aggiebronco
1978 - 1996 Big Bronco
Jun 30, 2003 08:01 PM
