Offroad & 4x4
Ivanribic....
Old Jan 26, 2004 | 10:54 AM
fishmanndotcom's Avatar
fishmanndotcom
Ivanribic....
I was gonna e-mail you but i thought someone else might could use this info as well as i can!
I noticed you are running close to the same setup as I am only a few years older! My 208 is leaking and has some problems...what all did you do to get a 205 under yours? think you could get some snap shots for me? I know i will have to get my d/s's lengthened/shortened but what else did you have to do to the crossmemeber, tranny-to-t-case adapter, etc, etc!
thanx man
-jason-
Old Jan 27, 2004 | 01:08 AM
ivanribic's Avatar
ivanribic
Jason,
The 205 was in the truck when I got it. I do not have a crossmember under it , just a mount on each side that bolts to the frame. I plan to add a skid plate later for a little more support and protection but it doesn't seem to need any help. I would imagine that you could fab the mounts very easily to fit your truck.
I can't tell you if the C-6 to 208 adapter is the same for a 205. If not they don't cost much at all and pop up on ebay from time to time (follow this link to check out a picture of the adapter http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454090167 ).
Only other thing I can think of checking is that the splines are the same, which I think they would be as they'll make a transfer case fit the tranny, not the other way around.
I work out of town tomorrow but I'll crawl under the truck Wednesday and take a few pictures for you. From what I've read it should be a pretty simple switch. I just received my twin stick kit today so I'm planning to drop the case and install that next week. What fun!
Ivan
Old Jan 27, 2004 | 01:13 AM
fishmanndotcom
ooooooooooooooooo ok. i found out i shouldn't need a crossmember it just bolts to the frame! it is a 6 bolt, circular pattern with 31 spline.
thanx
-jason-
Old Jan 27, 2004 | 02:20 PM
ivanribic's Avatar
ivanribic
Well I got impatient and decided to snap a few pics at 5:30 this morning. I didn't have a light so I was shooting completely blind. Yeah, I'm retarded.
Of course as I look at these pictures I notice I'm pissing fluid everywhere, transfer case, engine, diff. Can't wait to get that cleaned up.
See if these help you out any:
You can see the crossmember under the tail end of the tranny, right behind the adapter
Better view of the adapter itself
I misinformed you last night about needing 2 mounts. Mine has none on the passenger's side as it's supported by the transmission
Here's a view of the mounting bracket. This is on the driver's side of the truck
And one more of the whole set up from behind
Old Jan 27, 2004 | 03:47 PM
fishmanndotcom
awesome man....thanx that really helps me out a LOT!
-jason-
Old Jan 27, 2004 | 07:06 PM
ivanribic's Avatar
ivanribic
While we're on it, does anyone know where to buy replacement mounts for transfer cases? I'm looking for something to replace the rubber cushion as it's falling apart.
Old Jan 27, 2004 | 10:22 PM
Ford79's Avatar
Ford79
]Jeff's Bronco Graveyard has them
