Idling Issues
Old Jan 26, 2004 | 06:18 AM
bikehike's Avatar
bikehike
Idling Issues
Good Morning All,
For the past 3 months I have been noticing an idling problem with Ranger. I have a 1996 3.0 4x4 extended cab Ranger that is still in excellent shape. I have been noticing that when I go to start the truck sometimes it will not idle correctly. This issue is also intermittent and seems to be enhanced the colder it gets outside. When running correctly it firsts idles at 2 grand and then works it's way done to about 1 grand when it starts warming up. When it is having issues idling it will not go above 1 grand. Sometimes I have drive it for a while before it starts idling correctly. Please give somewhere to start so I can fix this problem. It's getting annoying when it's -20 degrees and I have sit in the truck to keep it running.
Thanks
Rob
Old Jan 26, 2004 | 07:27 PM
Dealford's Avatar
Dealford
If the tune-up parts are fairly fresh, then you may want to clean the fuel system &/or see if there are any codes present.
Old Jan 26, 2004 | 08:31 PM
Ken00's Avatar
Ken00
Sounds like a sticky IAC, I would cleam or replace it.
Old Jan 27, 2004 | 05:24 AM
bikehike's Avatar
bikehike
IAC??
Hello,
Thanks Ken00, sorry for my ignorance but what is the IAC? I will also look it up in the Ranger manual.
Thanks
Rob
Old Jan 27, 2004 | 10:00 AM
NorthPac's Avatar
NorthPac
When engines get over 80 thousand miles
Do a complete tune-up :-)
check for codes on a good scan tool, because a good scan tool it can show senors that are weak like the o2 senor/s. replace the o2 senor/s about 85, miles, clean or replace the MAF, ICA, ITA, ECT senors, clean thougherly the throttle body, check all vacuum lines including brake booster line & the check valve, replace rubber old lines & vacuum stops. check wiring throughout for rubbing wear, clean electrical connections, replace filters, clean pcv valve, replace spark plugs and wiring, do a compression check, change auto. fluid, clean both the radiator & tran cooler, buy a good fuel injector cleaner, use ever 3000 miles
Old Jan 27, 2004 | 03:51 PM
Ken00's Avatar
Ken00
Idle Air Control valve, it controls the idle speeds, normally located on/near the throttle body.
charlieranger
13
Aug 8, 2012 11:21 AM
Freightrain
Dec 31, 2011 01:01 AM
overtimef250
Sep 15, 2011 01:24 AM
aletheuo
Aerostar
Jul 13, 2008 10:42 PM
