7.3l smoking when started
Old Jan 26, 2004 | 12:19 AM
Shafer's Avatar
Shafer
Trailering
My 95 7.3L smokes when I start it Ambient temp does not matter. I have noticed that the volt meter is low while it is smoking aswell. Then like a switch the smoke goes away and the volt meter registers much higher. Has anyone else notice any thing like this?
Thanks
Old Jan 26, 2004 | 02:17 AM
Quadzilla's Avatar
Quadzilla
What you're describing is fairly normal. The voltmeter will register a low reading while the glow plugs are activated, which can be up to 1 1/2 minutes after starting the truck.
If the smoke you're describing is light blue in color, that's merely an indication that you're engine isn't warm enough yet to burn the fuel efficiently.
Since the smoking stops when the glow plugs stop cycling, I wouldn't worry about it.
Old Jan 26, 2004 | 06:32 AM
powerstroker250's Avatar
powerstroker250
What Quad said
Old Jan 26, 2004 | 12:23 PM
BluesManF250's Avatar
BluesManF250
Yeah mine does the same thing on occasion when its really cold. Light blue smoke on initial start up and by the time I get out of my development, it disappears (i.e. warmed up).
Old Jan 26, 2004 | 07:59 PM
Shafer's Avatar
Shafer
Trailering
If it was just a small amount of smoke I won't be concerned. But it can fog up a fairley large area in short time. I would even say it billows blue is white smoke. I can not start it and run it in the shop even in the middle of summer. I do believe it is unburnt fuel though. It is a white smoke with a blue tint.
