1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Odometer Blackout Problem Fixed!!!
Old 07-27-2015, 04:02 PM
Mywarrior's Avatar
Mywarrior
Mywarrior is offline
Originally Posted by Atlcam88
I must be the biggest idiot known to man I can't get the friggin headlamp bezel off!! I don't want to break it but I feel like I'm to that point I'll just replace it if I have too... I have the headlamp **** off but all I'm doing now is marking up my dash... Any help is much appreciated
Mine was just held in with clips and popped out with a flathead screw driver. In mine there is a square slot in the bottom center of the bezel for the screwdriver Once it comes out a little bit you disconnect the wires.
I've read in the comments and other threads of the forum that different year models are slightly different though. Mine is a 2000 F150 Lariat 4x4.
Hope this helps. Good Luck
  #392
Old 07-29-2015, 07:29 PM
Atlcam88's Avatar
Atlcam88
Atlcam88 is offline
thanks warrior... I finally mustered up the courage to just go ahead and get it out no matter what. Here is what I found out about my 1999 Ford Expedition Eddie Bauer AWD 5.4L with auto leveling suspension...
This is how the panel switch looks put together off the dash.
Remove the **** by depressing the tab through the bottom end of the ****
I broke the top panel off and this is how it looks underneath. Mind you mine has auto lamps.
Here where my finger is there is a lever.
Moving the lever right disengages the clip holding it in place but be careful it is spring loaded!
The lady I bought my expedition from said it had 198k on the clock but after fixing it she was a little off... 😜
  #393
Old 08-01-2015, 09:18 AM
alloro's Avatar
alloro
alloro is offline
Received 4,207 Likes on 2,441 Posts
Nice pictures, very clear and focused.
  #394
Old 08-01-2015, 11:23 AM
Skauber's Avatar
Skauber
Skauber is offline
Although, I'd be very surprised if I found an engine inside one of those *****..
  #395
Old 08-02-2015, 12:41 PM
alloro's Avatar
alloro
alloro is offline
Yeah I was also kind of wondering where the picture of the engine fit into the story.
  #396
Old 10-25-2015, 04:04 PM
12tk's Avatar
12tk
12tk is offline
Bad Solder Job?
I tried fixing this issue before I found this post and was using someone elses post. They said to use plenty of solder. I've never soldered before so I put plenty on alright. In fact I put enough on that now all of the prongs are soldered together. I put everything back in the truck and now the truck will turn over but it won't start. When I turn the key on, the odometer does not light up and the gauges do nothing. The lights for the door, seatbelt, and battery do light up. Do you think I messed the whole thing up by putting to much solder on? Do you think I can melt it back off? Is this the reason the truck won't fire? I noticed I now have a green and orange wire laying under the dash that I can't figure out where they used to be connected. They are tied into a large style 10 amp fuse.
  #397
Old 10-25-2015, 05:13 PM
12tk's Avatar
12tk
12tk is offline
Well, I melted all of the excess solder away and she started right up and now the odometer and gauges are working perfectly. However, I'm still not sure where the wires are pulled loose from.
  #398
Old 10-25-2015, 10:56 PM
Skauber's Avatar
Skauber
Skauber is offline
If you short out the wires by soldering them all together, they will of course not work anymore. About the wires, unless someone with a 1. gen chimes in on where they go (a picture would be very helpful), your best bet is to study a wiring diagram from the factory service manual, if you don't know how to read a wiring diagram, perhaps you can ask a friend who knows.
  #399
Old 10-26-2015, 09:33 AM
alloro's Avatar
alloro
alloro is offline
Considering the large 10-amp fuse, it sounds like some kind of aftermarket device that a previous owner had installed and removed.
  #400
Old 11-02-2015, 06:09 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
Makes me thankful I haven't had this problem yet. I continue to have the problem with the radio, probably a second junkyard swap soon.
  #401
Old 11-30-2015, 10:35 PM
tpicha's Avatar
tpicha
tpicha is offline
2005 f250 supercrew 6.0
my odometer goes in and out also but when i took it apart i could wiggle the left plug on top and it would go in and out but couldnt see the problem. any help out there?
  #402
Old 12-01-2015, 08:46 AM
alloro's Avatar
alloro
alloro is offline
You might need to just clean the connector contacts.
  #403
Old 02-25-2016, 09:30 PM
BillEJames's Avatar
BillEJames
BillEJames is offline
My 2004 has the blackout odometer issue. I look at that thing many times a day, g0tta squint at my age but I'm gonna try this, looks easy enough. I've got a pencil soldering thinga-ma-jig too. Thanks Very much!!
  #404
Old 02-25-2016, 10:06 PM
rickcroom's Avatar
rickcroom
rickcroom is offline
Bill,
It is real easy. You will not regret it.
Good luck.
  #405
Old 02-28-2016, 10:16 PM
cbx's Avatar
cbx
cbx is offline
Years ago, I could find my way around and post to the proper forum. Now the site is either way harder to get around on or I am a lot more confused than I used to be. This is my apology for this being in the wrong area, if it is. I have a 2006 Explorer Sport Trak with the AM/FM 6CD with subwoofer and IPod connector in the center console. The display blacks out but will occasionally come on. Is there a quick fix or must I replace the whole unit?
Quick Reply: Odometer Blackout Problem Fixed!!!
