vin number help
Old Jan 25, 2004 | 07:32 PM
Rob from wv's Avatar
Rob from wv
Question vin number help
can some one decode this vin number for me i just got the truck and i think a lot has been changed.
F37HCCA5860
tHANKS
Old Jan 25, 2004 | 08:08 PM
BamaF100's Avatar
BamaF100
if i am not right about this,its cause im a newb
Model Year: 78
Series: F350 - 4x2 Chassis & Cab
Engine: 8 Cyl, 351ci (5.8L) 2bbl
Assembly Plant: Ontario Truck
Old Jan 25, 2004 | 08:22 PM
Mil1ion's Avatar
Mil1ion
Looks right to me
Old Jan 25, 2004 | 08:49 PM
BamaF100's Avatar
BamaF100
I learned from the best
Old Jan 26, 2004 | 06:20 PM
Rob from wv
Ok thanks
but my truck
is now
a 4x4
has dana 60 in rear is that right for a f350
has a old style knockle front dif with big hubs a dana 44
a 390 4 speed
has the hi/ low range transfer with the divorced transfer case
has the pto io the trans side
here is my door tag info
w.b/137 color/m type/gvw/f378 body/g8a trans/a axel/27j 10,000maxgvw dso/87
this is the way i got it
I know things have been changed \
Old Jan 26, 2004 | 07:00 PM
78fordman's Avatar
78fordman
Well, that 390 was not original motor, the FE series stopeed in 76. I think it was a cab swap. Because every 78-9 4x4 i have seen has a married transfercase. I bet it is like a 75 or 76. Does it have front disc breaks?
Old Jan 26, 2004 | 07:06 PM
Rob from wv
no it has drum brakes
I have the title to match the cab
i know a lot of things get changed just asking ?????
Old Jan 26, 2004 | 07:07 PM
Rob from wv
did they use a dana 60 in a f350?
Old Jan 26, 2004 | 08:59 PM
78f3504x4's Avatar
78f3504x4
You might have an old closed-knuckle front 60. Low-pinion, drum brakes.
Old Jan 26, 2004 | 09:24 PM
Matts72's Avatar
Matts72
Your rear is not right, should be a Dana 70.
I'd bet somebody swapped a 73-6 F250 4x4 chassis under that cab, or over whatever floats your boat .
In which case the Dana 60 and Dana 44HD is right, you only have a 3/4 Ton.
Old Jan 26, 2004 | 09:41 PM
Rob from wv
a 3/4 ton is ok i am just asking what is up i know something was not right
blue_gill_slayer
1947 and Older Ford Trucks
Jul 13, 2012 11:51 AM
Snobord28
Mar 7, 2010 10:17 PM
ynkstr
New Member Introductions
Mar 28, 2008 02:49 AM
jmm
Jan 11, 2008 07:31 PM
tojaho
Oct 19, 2003 02:03 PM
