88 F150 Rear Window Rust
Old Jan 25, 2004 | 06:57 PM
Bikeitswift's Avatar
Bikeitswift
I picked up an 88 F150 XLT Lariat Extended Cab (105K) that is (Texas Typical) rust free except for a nasty 1" spot below the rear window gasket right on the "seam" on the drivers side, Its totally bubbled, and I'll have to grind it away. Is this a common spot that gives problems on this truck? The truck has a sliding rear window, and I suspect that whoever did the install did not seal it properly. I plan to pull the window and rust treat the entire seam when I do the rust fix. Surely you guys in the rust belt can lend some insight here. Thanks!
