pyrometer mounting location
Old Jan 25, 2004 | 03:40 PM
Tasslehoff13's Avatar
Tasslehoff13
I have a quick question about mounting location for the pyrometer probe. Most kits seem to direct installation into the Turbo down pipe or the exhaust manifold, but another site suggests the probe shoiuld be placed berfore the turbo. I'm a bit confused. I had planned on adding the gauges to my truck before I mess around with any other mods so I can keep an eye on things. I'm about ready to add the 3" turbo down pipe and eliminate the muffler and cat. Thanks for the help guys!!
Old Jan 25, 2004 | 04:25 PM
BigBully's Avatar
BigBully
It is best to install it in the manifold. The downpipe is Post turbo and temps can vary 300 Degrees from Pre Turbo. Most everyone Installs it in the drivers side Manifold almost to the rear There is a Nice spot to drill and tap.
Old Jan 25, 2004 | 06:04 PM
gcduece's Avatar
gcduece
The next thing you need to do is talk to BigBully about a pod to put your guages in! I have mine mounted in the manifold also. duece
Old Jan 25, 2004 | 10:30 PM
Bigsilver95's Avatar
Bigsilver95
Probe install
Gauge Install
Old Jan 26, 2004 | 08:28 AM
Tasslehoff13
Thanks guys ! Awesome links Bigsilver95, shoulda known better an just gone to the Diesel Stop my self !
Old Apr 8, 2004 | 04:56 PM
vettehauler's Avatar
vettehauler
Thanks again Bigsilver95.....your links just saved me alot of wasted time and effort.
Old Apr 8, 2004 | 05:06 PM
johnsdiesel's Avatar
johnsdiesel
The exhaust manifold is before the turbo. Pre-turbo is the only way to get an accurate reading of EGT's. Post-turbo is better than guessing, but will never give you an accurate reading.
