Sponsored by: Auxito
flashing check engine light
Old Jan 25, 2004 | 11:37 AM
bigtonto's Avatar
bigtonto
I have a 97 Ford F-150 4.6 V8. The check engine light has come on several times and I took it to the dealer. The diagnosis was misfire in #7 cylinder. After paying the shop twice for the same result. I left the light on since the truck was running fine. I changed plugs a couple of months ago and all was fine. Recently the check engine light began to flash and the engine is running really rough. I will take it in for diagnosis tomorrow but thought I would see if you had any ideas.
Old Jan 25, 2004 | 11:45 AM
LxMan1's Avatar
LxMan1
Hi and welcome to the forum
Probably a bad plug wire, did you change them too?
Old Jan 27, 2004 | 09:13 PM
rchristin's Avatar
rchristin
Have exactly same problem. Seems to be tied to wet weather. Did your diagnosis show anything?
