auto re-start
Old Jan 25, 2004 | 11:07 AM
Bossman7121's Avatar
Bossman7121
auto re-start
I'm wondering if anyone has or has built themselves an auto re-start system for time when the battery drains down. I have numerous rechargeable items, an onboard food cooler/heater, and need to leave these things plugged in. When the battery level drops, is their a system besides that will work with the remote start I already have to start the truck and let it run until the batteries re-charge up to a certain point?
Old Feb 24, 2004 | 05:27 PM
rumblefish73's Avatar
rumblefish73
Get a battery minder and just wire in a relay between the alarm on the battery minder and the trigger on your alarm's remote start feature. Problem is that most of your remote starters only run the motor for 5 to 15 minutes and then the motor cuts off waiting for you to insert a key. You would be better off just putting a trickle charger on your truck permenantly and hooking it up like you would a block heater every night to your AC.
