Sponsored by: Real Truck
SD Super Cab - Interior organizer - need some input pleeeeze
Old Jun 12, 2002 | 05:50 AM
Double Tap's Avatar
Double Tap
[updated:LAST EDITED ON 12-Jun-02 AT 06:53 AM (EST)]My SD Super Cab is due any day. I work rescue and carry a fair amount of gear with me. Most of it stays in a back pack that will stay in the back floor board behind the drivers seat. The rest will stay in the truck unless needed. I have been looking for something to help keep things "put" under the rear set. Ford sells a platic drop in unit for the SD, but it is $115.
Does anybody out there have, or has seen anything like this elsewhere?
Thanks in advance.
DT
Old Jun 12, 2002 | 10:18 AM
NoMo's Avatar
NoMo
I think that you'd be better off to build your own box. Measure & cut to fit perfectly plus compartments (if desired) built to fit your needs. Shouldn't take much wood- there isn't a lot of room under the seat.
Old Jun 12, 2002 | 11:46 AM
odie780's Avatar
odie780
