Just got my first CEL. Had already bought C-reader off E-Bay for $45 (included shipping). Code I got reads 0153. Book says "Bank 2 Sensor 1 for Oxygen Sensor's Slow Response." I've been searching threads and realize Bank 2 is Driver's side for my 99 Ranger w/4.0, however I need to know if this is sensor before the cat or after? Is it possible that "slow response" can be cured with anything but R&R?
It would be before the cat, and yes doing an R and R, should fix. Good luck let us know how it went. One tip, I found that they are not as hard to remove when they are hot. Just dont get burned. I have also found that an 7/8 wrench i have bent for different truck works well, and the new sensor should come with anti-sieze on the threads dont get this on the new sensor tip.
