codes 21,24
Old Jan 24, 2004 | 05:46 PM
pman26's Avatar
pman26
Unhappy codes 21,24
i have a 1991 ford ranger 2.3 5 speed 2 wheel drive truck wont start getting codes 21,24 will these codes make the truck not start? any help would be lovely
Old Jan 25, 2004 | 08:42 PM
Ken00's Avatar
Ken00
They shouldn't cause a no start. Are you getting a spark and do you have fuel pressure?
Old Jan 25, 2004 | 11:44 PM
87 XLT's Avatar
87 XLT
Ken, could the 21 be causing it to be too lean to start??
Old Jan 26, 2004 | 07:25 PM
pman26's Avatar
pman26
no spark nofuel can hear fuel pump though pressure around 14 does this help you any? truck was running then quit cranks but no start
Old Jan 26, 2004 | 08:06 PM
87 XLT's Avatar
87 XLT
Well I see that 21 & 24 can be caused by the engine not being warmed up. 24 can also be "Electronic distributorless ignition system fault-failure in coil one primary circuit"
Have you checked for 12 volts at the "batt" terminal on the coil. Just curious, but what does your Haynes say is normal fuel pressure??
Old Jan 26, 2004 | 08:42 PM
Ken00's Avatar
Ken00
21 could case a lean condition but it shouldn't be a starting problem. 24 is the ECT so your right, its not warmed up.
35-40psi is needed, make sure you cycle the key a few times if you still get 14.
Old Jan 27, 2004 | 10:24 AM
87 XLT's Avatar
87 XLT
Thanks Ken, now I know.
brcwelding
Apr 21, 2013 05:57 PM
Quigles4
Jan 27, 2013 12:32 PM
stvsr1
Feb 28, 2005 06:14 AM
cappercan
Aerostar
Mar 6, 2004 02:07 PM
bcastill
Mar 30, 2002 02:59 PM
