Which oil to use
Old Jan 24, 2004 | 03:48 PM
Ranger354's Avatar
Ranger354
Which oil to use
Hello. I own a 2000, F150 4X4. I've owned it for about 3 years now and have gotten used to the low mileage, noisy valves, etc. Currently I use the Ford recomended 5w30 oil. This is a lighter weight oil than I'm used to running. I would like to go heaver 10\30 or better. "But I'm kinda scared to. Has any one seen any problems running a heavier weight oil? Other than driving to work it's mostly used to pull my boat. Also I live in East TN. so the cold is not a major issue. Any suggestions? Thanks, Ed
Old Jan 24, 2004 | 04:39 PM
MJEmerson's Avatar
MJEmerson
A lot of guys on this forum run 10w30. I have always ran the 5w-30. I tried running 10w30 and did not really see any difference, so I stuck with the 5w30.
Old Jan 24, 2004 | 05:37 PM
b2_tim's Avatar
b2_tim
I wouldn't hesitate
to use a good 10W30 oil. Im using it now in Indiana in a Bronco II, and I can tell you it is a lot colder than in the Vol state. It (might) help the noise issue, and will probably hold its viscosity better than the 5w30 you are working with. 10w30's have less polymer viscosity extenders, and I'm seeing some other people post better results for oils that have a less of those extenders. Also use a motorcraft filter on your next changes, it has a good silicone anti drainback valve which should help quiet'n your startups. Good luck. Im using 5w20 in my new F150, but after the warranty is up, its a steady diet of 10w30 from then on.
Old Jan 24, 2004 | 07:23 PM
BrianA's Avatar
BrianA
Hello Ranger, welcome to FTE and the 4.2 forum! Here is a link to a thread in the Oil and Lube forum that you might find interesting.
https://www.ford-trucks.com/forums/s...hreadid=153899
Also, there's one here in the 4.2 forum about a month or two back.
Personaly, I believe you can't go wrong with any of today's quality oils. There are variations from oil-to-oil, but most all seem to pass muster. I prefer Chevron 10W30, but take your pick, there are many to chose from.
Again, nice to have you around.
Old Jan 25, 2004 | 05:41 PM
Ranger354's Avatar
Ranger354
Thanks for the info, and the link. I checked it. Probably changing to 10/30 on the next change. Thanks again!!
