Carb info needed
Old Jan 24, 2004 | 01:18 PM
lee's Avatar
lee
Carb info needed
Hi all,
I am working on a 1968 F100 that has a 360 and a 2 barrel carb. I am looking for info on this carb. The only thing I can find is "Motorcarft" stamped on top. There are no other numbers or stamps on it. What I need is:
What CFM 2 bbl carb's came on this engine?
Is the bolt pattern the same as a Holley 2300 series?
Thanks,
Old Jan 24, 2004 | 05:39 PM
390fe's Avatar
390fe
Without knowing the carb numbers, I'd have to guess the carb flows about(??) 500cfm. And yes, the bolt patterns should be the same for the two carbs. Unless the patterns are different! :-) Compare the two before forking out any dough if possible.
Old Jan 24, 2004 | 06:06 PM
lee's Avatar
lee
Hi,
I did finally find some numbers.
Venturi size is 1.08
The number on the base is 3TA8.
Thanks,
Old Jan 24, 2004 | 10:18 PM
pward76's Avatar
pward76
You have the Autolite/Motorcraft 2100 or 2150 (basically the same carb). Mine is the 1.23 venturi and I'm told it's about 350 cfm.
You can check Pony Carbs for some more info.
http://ponycarburetors.com
Check this website for rebuild info...
http://hurtle.com/cars/mustang/fixes/carb/
Old Jan 24, 2004 | 11:07 PM
Comegetsome's Avatar
Comegetsome
CFM Rating is 287 with a Venturi size of 1.08
Old Jan 27, 2004 | 09:08 PM
baitmaster's Avatar
baitmaster
bigger carbs
Had that 350 cfm on my 390 when I bought it, later installed 500 cfm 2 bbl Holley. Big difference in get up and go, but after rebuild got rid of 80 lb intake mani, and put Edelbrock and 4bbl Holley on it. NOW we're perking up!
