gear ratio
Old Jan 24, 2004 | 10:17 AM
tess100's Avatar
tess100
gear ratio
does any one no how to tell rear end gear ratio with out taKEING IT APART i think i have 410 but dont know for sure , also how much would 38 inch boggers change gearing
Old Jan 24, 2004 | 10:16 PM
kspilkinton's Avatar
kspilkinton
Jacking both rear wheels in the air and counting rotations of the drive shaft vs. rotations of the tires will give you a ball park estimate. The change in gearing would depend on stock tire size and gears.
-Kerry
Old Jan 25, 2004 | 01:07 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Sometimes there is a metal tag attatched to one of the diff cover bolts that has the ratio stamped in it. I have also seen it stamped into the cover itself. If you have a tach and know your engine rpm at any mph in drive, or whatever gear gives you a 1:1 trans ratio and know the diameter of your tires, there are ratio calculators that can tell you what the ratio is. Go to any axle gear parts website www.precisiongear.com www.ring-pinion.com and use thier calculators.
Old Jan 25, 2004 | 03:42 AM
95f150's Avatar
95f150
Look inside your drivers side door. It will tell you what it originally came with as long as a previous owner didnt change it.
