Leaking Slave Cylinder
Old Jan 23, 2004 | 04:32 PM
1982fordf100's Avatar
1982fordf100
My 1995 F150 with the 4.9 and M50D is leaking fluid from the slave cylinder. How hard is it to replace the slave cylinder? I am also going to replace the clutch at the same time. How hard is it to remove the hydraulic line that goes into the slave cylinder? Is there any special tools need to replace the slave cylinder? I have replace a clutch before so i should be good on that part. Any help is welcomed, Thanks Fred
Old Jan 23, 2004 | 04:43 PM
opporll's Avatar
opporll
I dont know, but the same thing just happened to me and its costing me $975, with the clutch, throw out, master cylinder, and fly wheel resurface
Old Jan 23, 2004 | 05:03 PM
1982fordf100
I just called for parts, it $55 for a slave cylinder and $130 for a clutch, pressure plate and throw out bearing, If I where you do it yourself if you can.
Old Jan 24, 2004 | 08:19 PM
1982fordf100
Ok, guys I got the clutch hydraulic line out tonight after I made my own removal tool. I made it from a washer, that I cut a piece out of. And I finished it off with a screw driver. I had to pull on the tube quite hard to get it out. My dad and I got the transmission, clutch and flywheel out. Getting the new parts tomorrow and start putting it back together
Old Jan 25, 2004 | 12:58 AM
borin&strokin's Avatar
borin&strokin
Carquest has reman flywheels just as cheap as getting them turned at many shops. New ring gear, and no waiting/wondering if it is turnable.
