I tried a search and had no luck, so I will open with a dumb question. I have a '95 Bronco with a 351. Can someone PLEASE tell me where the diagnostics port is located? Also, I have an OBDII scanner (Actron). Will this work on the Bronco, or do I need to buy something else?
If it is the same place as '93 351W...open the hood and look at the fender/firewall corner on the drivers side. it is a couple of inches below the hood opening. The girlfriend has the truck right now or I'd snap you a picture. If your bronco is anything like mine, you will become VERY well acquainted with it's location.
