1978 - 1996 Big Bronco
No Heat
Old Jan 23, 2004 | 02:01 PM
Artimusg's Avatar
Artimusg
No Heat
I have a '89 with a 302 engine and I'm not getting any heat anywhere. the doors move to divert from floor, panel, defrost,etc. but only blows cold air. both hoses to the heater core are getting hot also? Any help would be great.
Old Jan 23, 2004 | 03:06 PM
bigbluebronco's Avatar
bigbluebronco
there is a vacuum in the back left corner under the hood and it is probably closed up. All you need is something thats about 6 in. long to prop the thing open and it will start to blow hot air.
Old Jan 26, 2004 | 10:17 AM
Artimusg's Avatar
Artimusg
Thanks, I changed the heater core this weekend and it's working fine now. there were no signs of leakage inside but after i took the heater core out I found it to be stopped up.
