Offroad & 4x4
Explorer 4x4 Stuck
Old Jan 22, 2004 | 05:02 PM
njxlt's Avatar
njxlt
Explorer 4x4 Stuck
A friend has a 92 Explorer 4.0 with 4wd. Right now both 4 hi and 4 lo lights are on and vehicle is stuck in 4wd. It would not go into 4wd at first but after contiuous pushing of buttons now both light are on and vehicle will not drop out of 4wd. While pushing the buttons I can see the volt gauge on the dash drop down to around 10 volts while holding the button down. Any help?
Old Jan 22, 2004 | 05:41 PM
Yeti's Avatar
Yeti
Not sure what they run in them, but my moms blazer just had the same problem. The relay was pulling, but the shift motor would not engage. Ended up replacing the shift motor.
Old Jan 22, 2004 | 07:15 PM
Greasemunkey357's Avatar
Greasemunkey357
well if it stuck in 4 low u have to have it in neutral to shift it out...otherwise try goin under the truck and smackin the motor that engages and disengags the 4wd...i ad one that was the same year and it did that sometimes..try it....it may save aggrivation and money...it looks likea window motor
Old Jan 22, 2004 | 09:38 PM
85351ho's Avatar
85351ho
when they get old and or dont get used much they tend to stick, you may wanna pull it and take a look. it may just need to be cleaned and lubed
Old Jan 23, 2004 | 09:40 AM
Jet Lizard's Avatar
Jet Lizard
This question would better address to Explorer forum, but I try to give my five cents on this matter.
Your friend would probably want to get the 4x4 switched off. The best way to do it is to remove transfer case shift motor and try to rotate t-case shaft manually. There are markings near this shaft saying 2H-4H-4L. Switch to 2H.
The reason for this breakdown is most likely the t-case shift motor failure. Looks like it stuck in between t-case positions.
It's not necessary to replace it, it repairs easily. In Explorer forum this issue is being disussed quite regularily. Unfortunately I don't remember the details. Must admit that my mechanic did the same repair on my Ex. It took not more than a hour and not much than 100 bucks in total (but the price is in Russia, not sure that the repair in US will cost the same).
With best regards,
Yuri
Old Jan 26, 2004 | 07:51 PM
njxlt's Avatar
njxlt
You guy's are the experts! Dropped the shift motor, cleaned and lubed and she switches like a champ! Thanks for everyone's help. Saved $300 big ones.
