brake question
Old Jan 22, 2004 | 04:45 PM
fordeverpower's Avatar
fordeverpower
brake question
My brakes drag and if I have to realease the pressure at the master cylinders lines what is the problem? The pushrod or booster or what?
Old Jan 22, 2004 | 04:56 PM
lastchance's Avatar
lastchance
Sounds like the pushrod coming out of your booster needs adjusted. If you pull the master cylinder off and look at the rod you'll see it can be screwed in and out slightly. There is a spec for adjusting it. If I get out to my shed later I'll check it out in the manual. I'm sure someone might beat me to it!
Old Jan 22, 2004 | 05:06 PM
fordeverpower
lastchance i don't think anyelse has the spec just laying around but i would be greatful if you could get it. I called a mechanic and he said there was a spec but i don't know what it is. thanks
Old Jan 23, 2004 | 05:02 PM
lastchance's Avatar
lastchance
Found the spec here Matt...now if I can explain it! My manual shows making a "gauge block"...I guess you could make it out of light sheet metal or even out of a manilla folder or something like that. It would be rectangular in shape, 2 15/16 inches wide. (Apparently to measure from the flat surface where the master cylinder bolts on, not the indented area around the push rod). It then shows a 3/4 inch wide slot cut in it that is 0.980 inch to 0.995 inch deep. (Your "gauge block" would end up looking like a big "C"). The 0.980 inch to 0.995 inch is the measurement the push rod would protrude from the flat mounting surface where the master cylinder bolts on. That spec is from a '78 Ford truck shop manual, I'm guessing it would be the same for the '79.
Old Jan 23, 2004 | 05:39 PM
Mil1ion's Avatar
Mil1ion
Look on my web site.
I have them there.
http://mil1ion.clubfte.com/FordRelat...trations2.html
Old Jan 23, 2004 | 07:09 PM
fordeverpower
thanks guys!
i plan on gettting to work on it tommorrow morning.
